1 - 3 of 3 Posts
I currently have a 2005 RSX type-s. The Car has been completely rusted out and I'm looking to swap the k20z1 into a 2008 Acura Csx with a manual k20z2. I'm bringing the k20z1 engine to a shop to be built while I prep the Csx to be swapped.
Will the engine bolt right up?
Will I have to use a different ECU and wiring harness to make this work?
From what I understand both z1 and z2 just have tuning and some differences in the head
Let me know if you guys have any tips for this swap and what kind of parts I will need to make this swap possible
Engine will bolt up. ECU and wiring harness would be the same, as long as you're using a compatible CSX drive by wire throttle assembly. Which means, you'd need to modify the intake plenum.
1 - 3 of 3 Posts
