1 - 9 of 9 Posts
So, I'm high off Adderall, Horchata, and Starbucks Coffee to cram early for my final on Thursday, BUT procrastination got the better of me.
Anyways, after seeing the Lotus at Eibach with a K20 retrofit, it gave me the idea to fix up my dad's SW20 that he uses as his beater car. So, will a K20 fit inside the bay of a SW20? I'm aware that there are other engines that are more suitable and potentially better to swap in but I wanna be the one to be different.
Swapping out the 3S-GTE for a K20? Doesn't make any sense to me.
As someone who has swapped in a K20 to a mid-engined car before, let me tell you it's going to cost a LOT of money and cause you a LOT of headaches. You're going to spend thousands of dollars, it will be slower than stock and it's not going to be near as reliable. That's giving up a lot just to be "different." Don't do it. You would be so much better off just using that money and time modifying the stock engine.
If your going to swap anything into a SW20. Swap in a V6 Camry motor. 3VZ. Check out my friends SW20. I am looking for a nice shell myself for a track car and we are going to stick in one of the newer V6 Camry motors.
YouTube - Sw20 mr2 with 3vz
Listen to her roar...its addicting and the torque is nice when that motor is in that little car. The swap was really easy and a very popular thing to do in the UK! Just imagine a boosted V6 in that car...
This is a good option to go with. Most guys on MR2OC state that swapping in a k20 is a total waste of money.
ive got a 350whp 3SGTE powered SW20... a K20 into an SW20 sounds fun to me... especially if you did a K24 hybrid, cams, headwork, high comp, and around 300whp NA and a hell of a lot lighter than the 3S.... i think a stock K20 into an AW11 would be a lot more fun.
Matt
Discussion Starter · #9 ·
Matt
That's what I was thinking, lol.
What's a popular swap for the sw20 though?
Sent from my Droid
1 - 9 of 9 Posts
