A 1 1/2 inch drop is not that much. Some Honda Techs will tell that you dont need anything suspension/steering wise for a 1 1/2 drop except adjustable sway bar links. Dropping the car pre-loads the sway bar. This reduces the sway bars rotational arc and and will most def effect handling.
Honda suggests 0 toe because under acceleration the tires toe in. If you lower the car you will have more pronounced toe in under acceleration. You may want to go a degree or 2 toe out to help the car turn in. Adjusting toe is easy with some string, a ruler and flat surface.
Also, check to make sure your compliance bushing is in good order. Small cracks are fine but long and deep cracks are bad. This bushing when bad allows too much front to back movement of the LCA. Especially while accelerating while turning. Big improvement to handling when re-placed.
Front adjustable camber bolts. Get 2 for each side and you will be able to have the front camber adjusted to account for your drop.
All of these items will be less than the cost of a pair of roll centers and your entire front end will be much better off. I used a suspension geometry program to lay out my suspension and roll center is impacted little by a 1 1/2 inch drop. Toe, camber, and sway bar are more negatively impacted than roll center.
Link to the suspension program below
MacPherson Geometry Calculator
