1 - 10 of 10 Posts
K-Tuned CMC Upgrade
The 2006-2011 8th Gen Civic all have a known issue with their factory clutch master cylinders (CMC). If you look at the CMC on these cars more closely, you’ll notice that all of these models have a triangular shaped feedback plate positioned at the very end of the cylinder. This plate is basically a secondary valve that was designed to slow down the clutch engagement and reduce shock to the clutch itself and the surrounding drivetrain parts. This setup might be perfectly fine for people that just drive their cars for simple daily use, but the delayed engagement can cause wear to the synchros and possibly even the gears on performance applications. The reason is fairly simple, the factory CMC delays the clutch operation, so it does not open fast enough to keep up with a fast shift. This means that pressure is being applied to the transmission synchros during the shift, before they are ready for the actual gear change.
The K-Tuned Clutch Master Cylinder Upgrade Kit was designed to completely replace the original factory cylinder and offer real time clutch engagement to support faster shifting. We have put together a complete bolt-on kit that includes a direct replacement CMC, our high pressure 3AN clutch line, plus all of the necessary fittings needed for installation. The factory clutch fluid reservoir is reused and connected the same way it was in stock form. The only thing we suggest is checking out your slave cylinder on the trans to confirm it is leak free. Aside from that, installation is pretty simple, install the parts and bleed the system using some new clutch fluid.
K-Tuned CMC Conversion Kit - $157.49 + Shipping
Order Now - K-Tuned Clutch Master Cylinder - Dream Works Garage
Order online for fastest shipping possible. We have sold a bunch of these locally and are actually installing another one as we type this. We accept Visa, Mc, Amex, Dc, Paypal and cash. New Jersey residents must pay Sales Tax.
We will be closing at 4pm EST today due to the inclement weather. We anticipate being able to open for normal business hours on Monday.
Please be safe out there if you are in the NorthEastern Region of the United States.
Discussion Starter #9
Morning Morning Bump. Long weekend of Dyno Tuning and we are back at it again building a Turbocharged 9thGen Civic Si.
Please take the time to see our work online!
Facebook.com - Dream Works Garage
Instagram @dreamworksgarage
Visit our Webstore - Dream Works Garage - Homepage
Parts + Dyno Tuning + Fabrication
Discussion Starter #10
Monday Bump! Happy Presidents Day and we hope you are all enjoying the additional day off. To those in our area, don't let this Snow and Cold get you down!!!
DWG
1 - 10 of 10 Posts
