1 - 1 of 1 Posts
We've got too many of each on the shelf and gotta make some room!
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Now available for your 2006-2008 Civic coupe and sedan, as well as the Civic SI coupe and sedan, the K&N short ram intake features a beautiful silver finish and a trick heat shield.
2006-2010 Civic Si Coupe and Sedan:
K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range. K&N dynamometer testing shows a 7.01 horsepower gain at the wheels on the 2007 Honda Civic Si @ 6700 RPM, and a . The air intake tube has a CNC precision machined billet mass air adaptor and a radiused filter adaptor which smoothes the air flow entering the tube.
http://www.knfilters.com/dynocharts/69-1014_dyno.pdf
The heat shield isolates the K&N air filter (RU-5147) from the engine compartment. The engine bay layout of this vehicle places the air box in the back, up against the firewall. Here, it would be subject to lots of heat and little, if any, outside air. To counter this, Honda uses a flex hose that leads from the front of the vehicle to the factory air box to allow for a steady supply of outside air. K&N's air intake system takes advantage of this system by reusing the fresh air hose and connecting it to the base of our heat shield thereby supplying the K&N conical filter with cooler outside air the same way the factory system fed the stock air box when it was in place.
2006-2010 Civic LX, DX (non Si)
For the non Si, gains were 5.71 hp at the wheels and 5.28 ft/lbs of torque @5700 RPM
http://www.knfilters.com/dynocharts/69-1013_dyno.pdf
Installation is very simple and detailed instructions are included. Can be done in your driveway or garage with normal hand tools
Priced at $269 SHIPPED in all 50 states for the Si, and $239 SHIPPED to all 50 states for the non Si.
For shipping costs to anywhere else in the world, contact us with your full, complete address
To order, just give us a call at (631)863-3820
Thanks!
1 - 1 of 1 Posts
