1 - 16 of 16 Posts
i had my prokit installed few days ago and didnt notice my rear right is higher den the rear left until my friend told me is that normal? i have to wait for it to settle to even it out? sometime when i check it its both even but sometimes the rear right just sitting higher... the left is 1finger the rear is 1 and half finger space =/ thats weird anyone having the same problem? should i put some weight on the rear right to hold it down during the settle period?
no problems with my prokit. make sure the springs are not upside down "had a guy try to install them on my shocks like that i was like wtf. fix that. anyway other than that make sure the front are on front back on back
usually the right rear is lower than the left because of the axleback/exhaust.
:pat: the axleback barely weighs anything. 18 lbs does not make one spring lower than the others.
if this is true then
this means the rear left is heavier because of the fuel tank
or the front left because of the car battery
or the front right because of alternator and abs module
1 - 16 of 16 Posts
