were going to need a video and the dyno graph as soon as possible :biggrin:
:yeahthat:NIGHTHAWKSI said:you can run these without tuning?! how is your idle?
Without using clay to verify piston valve clearance or a mechanical drawing to take measurements from, you can also look at the cam lobe lift and duration compared to stock to give a good estimate of clearance.sinirgi said:just a noob cam question...
how did you figure out the piston to valve clearance was close?
