Ok guys,
So I finally got it installed. My flashpro came in today. I went through the whole fp install and reflash my ecu to the correct year, the correct mods, and the right injectors.
So I start it up...It will idle up down up down up down..between 1 and 1500 rpm..
So I text my tuner...he says the idle is norml and hell fix that, but when I go to take it out...Ill start to let off the clutch and the rev goes to 3...then down to 3 then down...Ill press the clutch back in..its rev to 3 again about 2 more times and then go back to the 1k to 1500 idle again...
Im stuck. IDK what to do. I dont have any starter fluid around to check for a vacumm leak so idk what to do from here..
