First you need to remove the negative ground wire.... 10mm Socket
Then you need to remove the rocker pannels... It will just unclip
Unclip the plastic piece around the lock...... It will just unclip
Remove the screw that was under the the plastic piece...... Phillips head screwdriver
Remove the kick pannel.... It just unclips
Remove this clip on the each side of the console
Remove the plastic pannel from under the glove box....... It just unclips
Remove the front bolts under the front seats...... (2) on each seat........ 14mm Socket
Remove the plastic piece from around the arm of the seat to expose the bolt that needs to be removed.... It just clips
Remove the bolt..... 14mm Socket...... (2) on each seat
Remove plasic piece on the side of the seat...... (1) on each seat...... It just unclips
Remove the bolt holding the seat belt...... (1) on each seat....... 14mm Socket
Unplug the (2) white plugs and the (2) yellow plugs under each seat then remove the clip holding the wire to the bottom of the seat
Now you can remove the seats but be careful not to scratch your paint..... Now that the seats are out you can get to the console better
Now remove the the shift knob...... Use an adjustable wrench on the lock nut and twist the knob off
Now remove the shift boot and trim ring off the console....... Pull up it just unclips
Now remove the console piece that has the storage part in it directly unerneath the shift boot and trim ring..........Pull up it just unclips
Now you will see (4) phillips head screws remove only the outer (2) that are holding on the console....... Phillips head screw driver
Now lift the armrest and you will see a little piece of black fabric remove the fabric and then remove the (2) phillips head screws underneath....... Phillips head screw driver
Now you can remove the console
Now remove the plastic pannel between the front an rear doors one on each side....... It just unclips
Remove the nuts (2) holding the gas pedal bracket to the floor....... 10mm Socket...... Remove the dead pedal as well...... It just unclips
You DO NOT have to remove the back seat!!!!.... Just pull up on the seat and it will unclip..... Then you will see (2) clips holding the carpet down under the seat..... Remove the plastic pieces (2) under each corner of the back seat..... They just unclip
Now it is time to remove the carpet
You will have to cut the pices of carpet that cross under the console.......... There are (2) total....... Use a box cutter now you can remove the carpet......
Do not discard the old capet as it will now become your template to cut the holes and trim the sides of your new carpet
Now I used a piece of white chalk to trace the lines and holes
Here is how it looks once it has been traced with the chalk
Now that you can see the holes and lines use a box cutter to cut the lines and holes out
Now this is how it should look...... Now it is time to put it in the car
Now retrace your steps and enjoy.
This is how mine looked after I finished everything.
