Are there specific jack point to jack up the rear? Not the control arm because i have some suspension work to do. Appreciate it?
never on the tow hook. If you go a little deeper where the two control arms meet there is a piece of the frame I will show you a pic.there are three spots in the back, two along the sides in front of either wheel and one on the tow hook.
why not?never on the tow hook. If you go a little deeper where the two control arms meet there is a piece of the frame I will show you a pic.
well depending on the jack you have and the surface area of the jack head I would just prefer using the jack point i just said to lift it up. also I don't want to rely on a little surface area to lift up my car when i have a ton more just a couple inches awaywhy not?
you can use the tow hook.
Connects the two lower control arms.... well not really connects them but is supposed to add more rigidity...Thanks! Now the blue brace, what is it holding together? The tie rod right?
DOH the blue is an aftermarket thing. The jack point i am referring to is the frame the blue thing is connected to. right in the dead center. and it is held together by the lower arm control bolts. regularly there is nothing there. battle endless sells something that is suppose to hold everything together to add rigidityThanks! Now the blue brace, what is it holding together? The tie rod right?
