IPS will get the most votes but they are fairly expensive and hard to find,where as blueprint is fairly easy to find...Have you thoiught about GoPWR cams??
Click here for Go-Pwr cams.Don't know this brand. I will check it. If you have others brand tell me please. It's my daily drive and I want to have 12.5:1 CR max. I want to have high results.
Do some research for the k-series cams. It really depends on what you want.Why I'd choose these cams ? what they are in particular campareed to IPS
Woooord. ^
FYI you would not use the same cams for a K24 hybrid as you would a K20.
then BP is not giving you the best cam for one or the other.Abuilt K24 and a built K20 require different cams to make the most power and have decent drivebility...so basically they are selling a generic cam profile.IPS uses two different cam profiles for K20's and K24's,and if the leader in K-series cams does it then it's probably a good thing to do.only if your with go power. bp uses the same.
that's great....a race motor using their cam made almost 300...but what i'm saying is a cam specifically made for K24's will not work as well on a K20 and vice versa,if you believe otherwise then you really need to seek professional help.ill let the dyno speak for itsself
Blueprint Manufacturing - Quality Performance Parts - Camshafts Stage 3 K Series
