1 - 2 of 2 Posts
So ever since I had gotten this car (FG2) my front right dome light had an issue that it would only turn on once every like 4 clicks, when you click it in and hold it in its on, then you release, and it turns off or flickers. Now the rear dome light started to do this as well, except instead of pushing up on it, it happens when I slide the switch over to one side and push up on the dome (even though it's not a push light). I can get video of this if you need it to understand the issue, the light won't always turn on when the doors are open either. I don't think it's a fuse or anything since the light intermittently turns on and depends on the pressure that I push on it or whether it's pushed in or not to turn on. Bulbs aren't bad either, recently replaced. Ideas?
1 - 2 of 2 Posts
