After seeing a DIY for interior lighting in the footwells, I decided to give it a shot. Now, since I pulled information from various places, thats the reason for a new thread... I dont want to askt he same things multiple places.
Anyways, the DIY writer said that he tapped into fuse #14 which was the headlights. However, in the 'FUSE GUIDE' thread.. the following info has provided.
I would still like to have these lights tapped into the light above/between the headrests, such that the lights come on when they do... ie: when i open the doors, then they fade out, etc etc.
I tested a few different options while trying to figure this out, and Fuse 14 and 15 appear to be one in the same. Both were only activated when I turned the Headlight knob one click forward. However, I dont understand how this should be happening.
Fuse 14 - 7.5 - Small Light (Int)
Fuse 15 - 7.5 - Small Light (Ext)
How are the headlights activated when the headlights are on the exterior? And furthermore... how come both fuses do the same thing?
Upon further research, it appears that the fuse for the light I am wanting to tap into is the #22 fuse which is actually under the hood. Has anyone been able to sucessfully tap into this dome light?
And one last question, what does the '7.5' or '10' or '20' stand for on the fuses?
Thanks for any and all help.
tomasro said:so which one is the map light fuse? Is it the "interior light" fuse location?
However, I would rather have them come on with the dome light between the headrests. So... having them come on with the headlights is an 'ok' temporary solution, especially since I rigged up a switch so I could turn them off manually.unplugged said:14. 7.5A - Small Lights (Int)
