1 - 4 of 4 Posts
The interior lights (in door position) of 2007 Civic Sedan will not turn off. All doors are closed tightly. Also, the reading lights are off and the light switch is in the door position. The lights should go off when all the doors close. Has anybody else had similar problems.
Check all the door switches individually and see if one might be defective. close all the doors, then go around to each door, open it and push in the door switch located on the door jamb by hand. Maybe one is stuck somehow
Its not you. The car is broken. Theres a little computer module that controls all of the inside lighting. It went bad on the '07 Si I used to have. Fixed under warranty.
1 - 4 of 4 Posts
