1 - 20 of 24 Posts
I found this article while doing some research on intake manifolds. I searched & didn't find it, so I hope this isn't a re-post.
K-Series Intake Manifold Shootout - K20A Type-R Engine - Super Street Magazine
Cliff Notes version:
All tests were done on an internally stock K20a.
Code:
		 HP	 TQ
PRC baseline	214	144
Ported RBB	 -0.2	+11.0
Stock RBC	 +5.0	 +0.6
Skunk2		+10.4	 +2.4
Ported RBC	 +5.3	 +1.3
RAA		-10.5	 +7.4
RRC		+14.5	 +8.6
Code:
		 HP	 TQ
Stock RBC	 +5.0	 +0.6
Skunk2		+10.4	 +2.4
RAA		-10.5	 +7.4
RRC		+14.5	 +8.6
From the test we did the on dyno back to back stock rrc vs stock rbc it was about the same everywhere ... the rrc did make 1-2 hp more up top by redline..... imo the rrc not worth it
ryan @ church auto
ryan @ church auto
What TB did you use?
ryan @ church auto
I have seen conflicting data on this also
You guys sure do like to try to be the authority on modifications.
Both of my buddies make amazing power with the RRC manifold.
looks like porting the RBC on a stock motor isn't really worth it. Gains might be better if a larger TB was used though. Would be cool to see that dyno graph.
Depends on if you intend on Big Cams and or FI or stock head. Stockish head or stage 1s I would go RRC. Also If you intend on using the 06+ civic Si TB, you would need to get the RRC b/c our TB wont fit on the Skunk2 unless they came out with a solution for that.
I have read that article so many times, the pages of my magazine are dog earred. From what I have read, the RRC is the way to go. I plan on using the Hybrid Racing TB when it comes out. I will have the RRC port matched as well. Given that I have IPS cams and will soon have a Go-Power custom header with 3" collector and a Full Race exhaust, it should perform really well.
1 - 20 of 24 Posts
