10
If you find this helpful drop a like
What you need:
5.5mm socket
8mm socket
10mm socket
12mm socket
Various extensions
Various pliers
1 gal of coolant
3 cans of brake cleaner
Intake gasket kit
Note: pics were taken during install
My car is slightly modified, yours may look different
1. Remove negative battery cable ( not pictured)
2. Drain radiator ( not pictured)
3. Remove cowl
Use a flat screw driver or prybar for the upper part
There are 4 12mm and 5 10mm bolts
4. Remove air box and filter
3 clips
Maf sensor
