1 - 2 of 2 Posts
Pulstar® Installation Instructions
NOTICE:
Pulstar® Spark Plugs are not pre-gapped for your vehicle.
1. GAP CAUTION: Do not apply pressure to the center electrode. Do not drop. Use vehicle manufacturer’s gap recommendation; not to exceed 0.055” (1.4 mm). For factory turbocharged or supercharged vehicles, do not exceed a gap of 0.025” (0.64mm). For all non-factory applications call 1-888-800-6700 or PM me :)
2. Disconnect the negative battery lead before installation to reset the computer on pre-ODBII vehicles (1996 or older).
3. Remove spark plug coil to access spark plugs
4. Apply anti-seize to the spark plug threads.
5. Apply dielectric grease to the inside of the coil/plug wire boot prior to installation.
6. NOTICE: If present, remove spark plug insert from socket.
7. Start plug installation using a 3/8” diameter hose or spark plug install tool.
8. Tighten to factory recommended torque using a deep socket (most models require 5/8”)
9. NOTE: Typical computer-controlled vehicles need to use one tank of gas before the benefits of Pulstar Spark Plugs can be seen. To see benefits sooner, disconnect the negative battery terminal during installation.
For additional information, PM me or contact us
@ 1-888-800-6700 Monday-Friday 8am -5pm MST
Email - [email protected]
Warranty Information
Discussion Starter #2
If you are not 100% satisfied within 30 days of purchase, return for a full refund.
1) You can return the Pulstar Spark Plugs for any reason within 30 days.*
2) Pulstar Spark Plugs will not harm your engine.
3) Pulstar Spark Plugs will last at least 50,000 miles.
4) Pulstar Spark Plugs will not void your warranty.
1 - 2 of 2 Posts
