1 - 4 of 4 Posts
Has any1 had cluch clearance problem w the CAI Injen set up w the J37 throttle body, mine is not yet perfect
that cause the the throttle body is sitting further away from the manifold, due to the adapter spacing it out , why are you using an intake thats smaller than the throttle body ,
3.5 inch intake with j37 is the ideal setup
I saw that the injen had the best hp gains when I did my research, then got the biggest throttle body that I could find for the bucks, then bought a 3"-4" elbow hose to match the throttle body/CAI and I have had pretty good gains. I know is bc of the throttle body size and adapter, and regardless of the size of the CAI, it will still be sitting in the same spot; what I was wondering is how ppl corrected this issu (clutch clearance w/ TB). I am about to put the dremmel to the work on both ends; lol
1 - 4 of 4 Posts
