1 - 3 of 3 Posts
One of my coil packs are not firing. I believe it may be from my ignition coil relay. I found the fuses, but the relays are unmarked under the hood, only marked by corresponding letters. I need to know which relay is my ignition coil relay. Maybe that is faulty on my car.
No it isn't my coil, as I switched it out with another known working one. The problem lies between the harness plug and the ecu.
Car is a 2011 Honda civic si.
Any other ideas on what it could be, would also be a great help.
The relay powers up all four coils, so if the relay were faulty none of the coils would work. They also share a common primary ground at G101. If you are sure the coil itself is working, you need to check the wiring between the coil and the relay/ground and ECM like you mentioned. ECM terminals C15-C18 for coils 1-4.
2010 Si sedan 86k for sale
Figure out what it was?
1 - 3 of 3 Posts
