hi guys
I have an idle problem. When I depress the clutch while changing gear or approaching the lights, the idle speed drops by 400 RPM and then it rolls up.
What I've done so far to fix this.
*spark plugs changed
*throttle body cleaned
*Pcv valve changed
*Throttle adaptation done 3 4 times
then i tried another throttle, still didn't work.
*maf sensor cleaned
*map sensor cleaned
*ignition coils changed
but i still have the same problem.I'm waiting for help if anyone can help thank you.
my car is european version with engine code r18a2
sorry for my bad english i use google translate
*Pcv valve changed
*maf sensor cleaned
*map sensor cleaned
