I think my sway bar is bent
1465 Views 7 Replies 5 Participants Last post by  Chaos Pilot
Hey guys I'll make a long story short I hit a curb a while back and I replaced the lower control arms and sway bar likes but my tires squeel when I turn right and I'm thinking my sway bar is bent I just don't have the money to take it to a shop I just wanted yalls opinion
Tire Wheel Automotive tire Vehicle Synthetic rubber
Wheel Tire Automotive tire Vehicle Tread
Tire Wheel Automotive tire Tread Vehicle
Tire Wheel Automotive tire Motor vehicle Tread
  • Like
Reactions: 1
1 - 8 of 8 Posts
Have you gotten an alignment yet? When I replaced my LCA's on my 06 EX I needed to get an alignment right away. Long story short, I trashed both front tires.
Not sure which trim you have but the non-Si front sway bars are semi soft so its really hard to bend one.
The alignment place said they couldn't do it apparently they also recommended I go to a auto body shop my car is a 08 Si
It's funny because a while back I smacked the curb just like you and ended up having to use camber bolts on my car because either the front strut or the knuckle got damage which is causing positive camber on that one wheel. Use 2 camber bolts on the affected side you and take it in for an alignment again and see what they say.
You could completely remove the sway bar. It isn't really necessary. I'd recommend you take it to a legit place for an alignment.
  • Like
Reactions: 1
I'd just upgrade to an Eibach or even one of the 24mm aftermarket bars. Or get an OEM one from Kijiji.
If he upgrades to a bigger sway in the front the understeer will be a bit more worse. derppyninja, if you need a front sway, I highly recommend snagging one from a junkyard - heck, it would be better to get a front sway off an LX/EX as they are a bit softer and makes the car actually handle much faster.
Are the sway bar end links you purchased adjustable? Why did the alignment people say they couldn't do the work? Is the car too low to put on their machine?
Also, make sure you did not bend your tie rod (outer). LMK about the above...
1 - 8 of 8 Posts
