1 - 20 of 27 Posts
I was fixing a pain chip on the right side of the hood of my 08 FBP si coupe. after wet sanding with 2000 grit sand paper then buffing it and using scratchX the chip is fine but i noticed a round spot ~.5 in diameter above the fixed area. it's black in the middle and light blue on the outer rim so it kinda stands out in my paint. it does not go away even after waxing. is this spot a result of over sanding that i did not noticed i was doing? and what can i do to fix it? i can't afford a paint job now? advice appreciated.
Acorns!
*isnt there a site someone listed here tha sells factory-match paint in rattle cans? i remember seeing a site where you plug in your VIN and you can get paint anywhere from the nailbrush to buckets for a boothe gun. lemme look around a little
edit: this isnt the same site but http://www.expresspaint.com/productcart/pc/step3.asp looks pretty promising? you can get it from an aerosol can to a pint. lol u could probably tape off the hood except that spot and carefully mist it on and then clear it. Followed by polishing to smooth it out of course
Discussion Starter · #18 ·
i went to an auto paint shop and the guy there told me that putting touch-up on it will look worse that it is now (because it is pretty smooth now if not for the color.) he said to leave it alone or repaint it. is this true? won't it rust? the thing to consider is i'm new to doing stuff like this and my skills are not very good as you can see from what happened. i'm kinda traumatized now.
Acorns!
you didn't get to the bare metal. You're seeing the base. As long as there is primer/base on the car it's not going to rust. If you see straight up metal - it will rust over time, which will require sanding it down, adding primer, and painting/clear.
Discussion Starter · #20 ·
wow that's a relief knowing it will not rust. because i can't really afford a paint job now. maybe in the spring or summer if it really bothers me. for aesthetic purposes, will the touch-up paint make it look worse? is there anything i can do to make it look better?
1 - 20 of 27 Posts
