1 - 12 of 12 Posts
that it's not good to rev the engine while you have the clutch in. but when you shift, don't you apply gas while you're letting the clutch out? isn't that the same thing?
yeah but i mean i thought thats how you're supposed to shift? clutch in, shift, clutch out while applying gas... is that not right?
oh dear
ive been doing that the last couple of days....
thanks for bringing this topic up.... and thanks for the replies.
umm hellllo....do u ever rev match?
1 Clutch in
2 Select lower gear
3 Tach up to engine RPM that will occur when the clutch is released
<minimizes clutch wear and engine braking>
4 Clutch out
1 Clutch in
2 Select lower gear
4 Clutch out
Double clutch?
Clutch in
Shift to neutral
Clutch out
Rev to desired RPM
Clutch in
Select gear
Clutch out
Discussion Starter #10
i'm just saying what it said in another thread. good point about launching... i guess thats why it's not good to do it?
HRP_FG2 said:
how the crap do u launch then if u dont rev it ???
I suppose you launch everytime you get out of a complete stop?
There is a clear difference between slipping the clutch and revving while stopped. you can rev it a little to get moving after that foot off the clutch. Some things are allowable.
And dont confuse a common question with a racing question two totally different driving styles when the moment is right.
Scrodums
They are not the same thing. There's some form of load on the engine when you are shifting and applying gas. There is no load on the engine when you dry rev the car.
1 - 12 of 12 Posts
