This is for a Si sedan. Criteria for my rims had to be JDM, big lip (relative to FWD), and 17" cuz I am going to use my stock tires. I am going for the some what "VIP" style look. Very similar to Berlinas2k2 Civic. I plan on using coilovers and drop it as low I can go without scraping the front on my driveway so my questions are:
1. How do you decipher the SSR sizing spec? I am assuming the numbers below "offset" are the lip sizes ie 34mm, 46mm, 59mm, 72mm. And then further broken down to the actual offset to what the wheels are.
2. Are initials SL (Super low disk), NR (normal disk), MD (medium disk), HD (high disk) correct? If so I am assuming as you go to the right the less lip you have SL(deep)-->HD(shallow)?
3. I would like to go with the 17 x 8 so looking at the chart I think the best size for maximum lip would be +37 NR under the "46mm Offset" is this correct?
Thanks in advance!!!
link to size specs
SPEC 17inch�bSSR Professor SP1
link to size specs
