301 - 320 of 334 Posts
· Registered
No I did not try that yet. I was trying to force the flat between the rubber and the metal ring portion. Its a little too dark outside now (and no garage) so I'll have to give it a try in the morning using your method. Thanks for the quick reply and I'll let ya know if it works out for me!
Just make sure to hold the cable very firmly between the part with the bushing and the bracket. You don't want the prying force to transfer to the part of the cable in the bracket. That can damage the cable. It's not hard to remove the cable using the method I described, but if you aren't careful the damage is possible. Another thing that makes the removal easier is prying between the rubber and metal with a flathead and spraying in some silicone spray.
· Registered
· Registered
I'm looking for the shift cable bushings shipped to 95831. Thanks.
Also, I'd like to know if there is a huge convincing reason for me to get the base bushing besides reducing the flex of the oem shifter? The reason is I should get the HR shifter kit(which doesn't use the base bushing at all) in 2 months, so I don't wanna spend my hard-earn money on something that I have no use with in a very short time.
· Registered
If you're getting our 8th gen short shifter, then I would pass on the bushings for the OEM shifter. The difference the bushings make is nice for the price, but if you're going to get the shifter in a couple of months, I'd just put the bushing money towards that. And it sounds like you already know that our shifter doesn't use bushings (it just bolts right to the cast aluminum e-brake assembly).
I can't say what price shipped is (I'm not in sales), but if you want a quote you can get one easily on our site by just adding it to the shopping cart and putting in your address.
~russ
· Registered
So I should still get the cable bushing even I'm getting the short shifter right?
Budget permitting, absolutely. The bushings and shifter both fix compliance issues, but they fix the issues of different parts. Just so that you can fully appreciate the changes each part makes, I would say put the bushings in, drive around for a few days to get a feel for the improvement they make, then install the shifter. That will give you a good idea of the effect each part makes.
~russ
