We cleaned up shop the other day and have some parts laying around that we don't need. Parts are "as is" unless stated otherwise. **Prices do not include shipping**
We accept paypal, CC, money orders, cash and checks.
12. NEW 8th Gen e-brake assembly as is $50:
14. Used 3.75 inch KN filter. Used on one dyno day $25:
15. USED 5 inch outlet velocity stack. Vibrant. Aluminum $20:
16. NEW OEM 9th Gen Civic shifter cables $125:
17. USED OEM EP3 shifter cables $50:
19. NEW OEM RSX shifter cables (needs brackets) $200:
20. Used OEM RSX Shifter $40:
21. Used OEM RSX Shifter $40:
22. NEW 96-00 Civic EKK1 aluminum mount kit. Black ano, green bushings, 75A (customer returned) $450:
23. USED 96-00 Civic EKK1 aluminum mount kit. Clear ano, green bushings, 75A (no bolts) $300:
24. USED 96-00 Civic EKK1 aluminum mount kit. Clear ano, green bushings, 75A (missing passenger side billet mount) $200:
25. NEW 96-00 Civic EKK1 aluminum mount kit. Black ano, green bushings, 75A, HAS A FEW KNICKS $300:
26. NEW 94-10 Integra replacement driver's side mount for B/D series, 75A, (black w/ green bushing) $50:
27. USED (2) tilton compact brake master cylinders with 3-chamber reservoir as is $100:
29. NEW ATI super damper for K-series $300:
30. NEW (4) Bosch 52LB Injectors. 0280 158 117: $150
31. NEW BluePrint K20 H-beam rods. Pre-Pin fit. Part # BP-5470H-CR $200:
36. NEW Hardrace swaybar bushings for 24mm sway bar on EG/DC2 $15:
38. New HR stainless standard kit $75:
41. NEW AEM Hybrid CAI $140:
42. NEW K-tuned bolt-on Radiator Relocation Brackets $20:
43. NEW K-tuned 8th Gen Civic throttle booster $50:
44. NEW K-tuned k-swap heater hose adapter fitting $10:
45. NEW Chase Bays CM2 (no vtec wire) K20 plugs $600:
46. NEW Aeromotive 11106 Fuel pump $250:
47. K24a1 bored and honed to 87.5mm **no crank** bare block (done by GoPower) $300:
48. k24a1 stock block **no crank** ("A" bore) 87mm $200:
