1 - 3 of 3 Posts
Hello guys,
Made the switch to the Hybrid Racing EM1 CMC. It’s bled and everything. Switched out the OEM rods into the new CMC, and it’s been adjusted to where there’s hardly any free play.
Let’s get to the problem: the pedal travel is a lot shorter than it usually is. From what I see on YouTube videos and from what I remember driving my car with the OEM CMC, the clutch pedal used to sit at the same height as the brake pedal, now it sits lower.
Do you guys have this problem? Is it normal? Should I switch out my CMC to the new updated product?
2008 Si Coupe k24a2 swapped
did you bleed it. And also doesn’t sound adjusted correctly nor does it sound like you bolted the 3 screws for the pedal correctly ??? Post some pics
Where the pedal sits is dependent on the cruise control switch/ dead stop above the pedal. Readjust your freeplay by changing the thread depth of that.
Also the em1 kit does have a shorter pedal travel.
1 - 3 of 3 Posts
