So I am getting ready to turn 100k miles so I thought I'd change the serp belt. Found that there was a potential issue with the pivot bolt and the way the belt was routed. So a new pivot bolt later (what a pain in the A) I have the belt routed but have no idea how to get the belt installed.
Let me elaborate.
First off, cranking the tensioner with the provided 19mm nut is hard! Does hona expect technicians to hold the tensioner up and put the belt on?
Basically, if you put the belt on all the pulleys and leave it off the tensioner pulley and then crank the tensioner with your wrench....you can't get to the tensioner. So then I am thinking the next best thing is to slide it on the water pump.
Any tips and tricks to get this belt on?
Let me elaborate.
