1 - 7 of 7 Posts
does anyone know how to do the wiring about the led light and the angle light for the halo project, the way i want it to comes on is when i turn the ignition to II it will turn it on at the same time. does anyone know how to do this?
You should try using the search function on this forum, i had the same question and it was answered using search....BUT
Theres a great thread on here for that that has step by step instructions to what you want to do...just search your question and it should come up. if not, google it
quick and easy wire it up to the signal lights. Close Thread!!!
What r u talking about? That's doesn't do anything requested by OP.
For OP, when I had that headlight, I power the LED with DRL + low beam, which is almost same as what u want, except you will need to release the hand brake at least once. With this I only need to splice the high and low beam adapter on the projector headlight and don't need to splice any OEM wire.
1 - 7 of 7 Posts
