how light do the rims have to be before you notice a performance gain?
I have an em2 also with 15" rota slipstreams and kumho ecstas the rims are 11 pounds a piece...I put them on after having 17's and the difference is tremendous...if you want lightweight rims, look into spoon sw388(I believe) or desmond regamasters the 16" weigh around 11 pounds...it helps every aspect brakes, suspension, acceleration.
I have a dc header, greddy cat back, motegi track light rims (15 lbs), aluminum skunk 2 rear adjustable arms, aftermarket coilovers (weighs less) and I notice (drum roll) 0% diffrence in daily driving. I figure I have shaved about 50-60 lbs and maybe 1/2 of that is unsprung weight. These kinds of small savings can only be noticed on timed laps and in my opinion changes in ambient air temp would have more of an effect than 50 lbs.
Yes you are absolutely correct...the difference is nominal especially when you don't do everything at once...but it is proven that weight reduction improves, lap times, 1/4 mile times.
I found this link to SS mag with info on weight reduction but the 2 points that are best...
100 lbs less weight = 1/10 of a sec of 1/4 mile
may not be tremendous, but if my money is on the line...I'd do it
18.18 lbs less weight = is the same as getting 1 hp...
again not tremendous but at this point if you shaved 60 lbs off your car this is the same as 3.1 hp...
one less mod for you to make!!
http://www.importtuner.com/features/0407it_weight_reduction_tips/index.html
