1 - 10 of 10 Posts
anyone knows how much oil to put in the si ???? i can't find my owners manual, thank......
4.6 i think. its in the very back of the handbook
chugiboi said:
4 qts and a half. or 5 qts. i usually put 5 qts, and have no problem.
i put 4.5 qt's allready still i just went pass the 1st dot...how much more to go the 2nd dot
just put 5 qts the most don't put anymore than that, then you're fine. give the oil time to go down first, to see if it's close to the second dot. usually 5 qts is enough.
how about everyone just do what the instructions tell us. 4.6
Discussion Starter · #8 ·
is the dipstick accurate, cause i put 5qt's allready and it's not even close with the 2nd dot, do u check it when the motor is cold or hot?
let the car idle for a few minutes to mix it all around. then try it.
with the 5 qts you will be fine but its more that what is reccomended.
1 - 10 of 10 Posts
