Hey all. I don't think this is a super common problem as I only found a few small posts on this topic from over the years, but I hadn't ever seen anyone post a fix so here we go!
So basically, inside the guts of the armrest is a plastic component that goes from the latch at the front to the spring loaded hinge in the back. Everything else bolts to this. This component is the main structural component of the arm rest and it seems to be what breaks consistently based on other's posts. Mine broke a few inches from the hinge, so when the arm rest broke away it left a jagged plastic part behind that the spring-loaded hinge pointed straight up in the air.
I didn't think that glue would be enough to keep it together, so I went with a combination of 1" aluminum strips and Gorilla brand 2 part epoxy (the one that comes in the syringe). I cut 2 strips, approximately 5" each, out of some 1" wide aluminum stock I had in the garage. The strips then had a few holes drilled in each one and the strips were then pop-riveted to the bottom of the arm rest. Be sure to place each strip a bit off to the side to avoid covering up the screw hole in the middle-bottom of the armrest. I also made sure to slather both sides of the crack with the epoxy to give it some additional strength, as well as got it under the strips. When I was done it looked like this:
So this may seem pretty unsightly, but the plastic cover that goes on the underside of the armrest will completely cover it and it shouldn't interfere with the sliding mechanism at all. I hope this helps someone!
Hi everyone, I am new to this forum as I got my 2008 Civic Si about 4 months ago.
So, my driver side front suspension is making a noise(started a week ago) whenever it's going over bumps/uneven roads. Went to a shop to check it out and I was told the driver side strut is on its way out. It's...
Any help would be appreciated on this. I have a 2005-2006 (?) CRV. I left it in garage for a couple months on trickle charger. When I returned, the battery appeared to be completely dead and would not charge at all. Replaced. ABS motor (thing with all the brake lines) runs constantly as soon as...
how fix my taillights no work everything is off no light on my licenses plate no fog light work...but when i push the brake it is work but just the brake light somebody help me with that please.....is a civic si 2007
i check the fuses is good
i check the bulbs is good
i check all wires is good...
My taillight fuse burned out twice and when I tried to replace it a third time, it doesnt blow but there isnt any power going to the fuse.
I put a 10a in there before and it blew so I know there is a short.
I've had aftermarket fogs for about 4 months, which worked fine until recently and I...
My brake light taillights and reverse just went out I think I plugged the wrong wire into a socket and blew a fuse does anyone know the location of the fuse also I'm throwing a vsa warning
