1 - 9 of 9 Posts
I've been pouring over the manual and I'm still stuck as to how you set the outside temperature guage.
Any suggestions guys?
It's on page 67 of the sedan owner's manual.
"Select the outside temperature display, then press the SEL/RESET button for 10 seconds. The following sequence will appear for 1 second each: 0, 1, 2, 3, 4, 5, -5, -4, -3, -2, -1, 0, 1 ...
When it reaches the desired value, release the SEL/RESET botton. You should see the new outside temperature displayed."
hm... what exactly does setting it do? like if it's off by a bit you can adjust it?
Yes exactly. If your car outside temp gauge isn't accurate, you can calibrate it within +/- 5 degree F. You'd need to get some thermometer that you trust to compare with the car in several different conditions. Seems like a lot of trouble but it can be done.
palindrome said:
Just press SEL/RESET multiple times until you see the "oil life" meter. It's this way on US models anyway.
i did it but it doesnt show me that gauge...
canadian models can?
1 - 9 of 9 Posts
