21 - 40 of 89 Posts
i just aimed mine.
i did 3 full turns up on each. how many did everybody else do?
does anyone know an easy way to adjust foglights without tearing everything apart?
did you install yours or your dealer did. The whole part where your supposed to drill a hole in the bumper with the template was for the adjusting screw hole.
Both headlights are now adjusted
for the driver side just remove the overflow tank, i've done it
its a pita to put back on, just as a warning
Thanks for the tip. Turns out that it was the obvious thing to do and I was just looking to complicate my life.
I can't believe that someone would pay the dealer to do this for them when all it takes is a 10mm socket and a whole 5 minutes of your life.
Oh, and the overflow tank just slid back in without any problems. Maybe Honda re-engineered it for 2008.
Now I can finally put my HIDs to some good use on the road at night.
No, adjustment is only vertical. It's also fairly easy to see the adjustment crown on the passenger side headlight. Just open your hood, look behind the headlight, and you should see it.
I myself have a 14" long screwdriver. LOL. Great for adjusting headlights...and protection. :rotfl:
Broke Baller
Hahaha!:rotfl: So 14" is long enough huh??? Thanks thats what I'm gonna get then.
the height should be LEVEL
lol
go 50 feet away, if ur being blinded, its too high
or mark off where ur rear side windows are (bottom of them) as far as height goes on a wall, drive 30 feet from it backwards, and aim to just below that line
legaly tho, it must be PERFECTLY LEVEL lol
21 - 40 of 89 Posts
