1 - 11 of 11 Posts
I've recently been able to source these nice plug-and-play horn adapters. They eliminate the need to cut, splice or otherwise your vehicle harness in order to hook up aftermarket horns. Check them out! Both options are priced at $8.50 delivered within the USA.
0S03 - This version is for vehicles with stock dual horns. Two 1-pin connector adapters w/grounds are included. Plug directly into the factory harness and connect up your aftermarket horns.
Horn Adapter Wiring (pair) - 0S03 - College Hills Honda
0S03A - This option is for vehicles with single horns. A single 1-pin connector splitter w/grounds connect to your factory harness, giving you the ability to install a dual aftermarket horn setup.
Horn Adapter/Splitter Wiring - 0S03A - College Hills Honda
Super Moderator
i have been wanting to get some hella's but i didnt want to cut up my harness
Probably a dumb question but is there an easy way to tell if I have single or double horns without tearing apart my car?
Do you guys not sell the dual horn kits for 07 FA5 anymore?
If not what are my options? Just this adapter and an 08 Accord horn?
Discussion Starter #9
We can supply you any Honda horns you like but if you go with these adapters just remember they will only work with aftermarket horns.
1 - 11 of 11 Posts
