Hi Guys - Did anyone get the Honda Survey asking about the MAX A/C button?
Are they planning to get rid of it? hmm...:waiting:
Here are some of the questions on the survey:
How did you learn about what the MAX A/C button does and how to use it? (Mark all that apply)
Dealer explained at delivery
Read owner's manual
Read Quick Start Guide
Previous vehicle had MAX A/C function
Trial and error
Other (please specify)
Do you like having the MAX A/C button available?
Yes
No
How important to you is having the MAX A/C button?
Very important
Somewhat important
Not very important
Not at all important
If equipped, the system automatically turns on the A/C, selects (little man sitting with arrow pointing towards his head), and switches to recirculation mode. Each indicator in the button is on when the MAX A/C is turned on.
Does the message adequately explain the functioning of the MAX A/C button to you?
Yes
No
How satisfied are you with the A/C system in general?
Very dissatisfied - Dissatisfied - Satisfied - Very satisfied
How satisfied are you specifically with the MAX A/C function?
Is your Civic the first vehicle you have owned? :dancing:
Yes
No
I do not like surveys, but I thought I'd share. :banana-wa
What exactly does the MAX A/C button do, does it just turn on the inside intake vents, the out-take vents at your fact, and turn the A/C on?
Or does it do something useful?
it makes the A/C air a closed loop inside of the car so that it is cooling allready cool air, it also makes selecting differant air flow options impossible without it turning off. In other words make car very cold.
They should be doing a survey about the vulnerability of the a/c condenser since it is exposed to rocks. I needed to replace my condenser due to rocks and I know there are quite a few people on here who have gone through the same thing. If they have an additional comments section on the survey you should mention something about this.
