That's more like it.It is the ratio between the volume of the cylinder, when the piston is at the bottom of its stroke, and the volume when the piston is at the top of its stroke.
Thank you. + RepIt is the ratio between the volume of the cylinder, when the piston is at the bottom of its stroke, and the volume when the piston is at the top of its stroke.
basically high compression means with aftermarket forced induction our engines will blow like a overfilled baloon poked with a needle. This is why successful FI requires a huge rebuild with low comp. pistons, stronger connecting rods, and stronger block sleeving. Kinda off topic but a bit of a warning to anyone thinking of the greddy or other turbo kits. Unless you prep your block for a FI set up for thousands of dollars before the kit your gonna need a new engine within 10K miles of high rev. driving.i know we have a high compression ratio, 11:1 right? what exactly does this mean in terms of the car though?
wut about a supercharger?basically high compression means with aftermarket forced induction our engines will blow like a overfilled baloon poked with a needle. This is why successful FI requires a huge rebuild with low comp. pistons, stronger connecting rods, and stronger block sleeving. Kinda off topic but a bit of a warning to anyone thinking of the greddy or other turbo kits. Unless you prep your block for a FI set up for thousands of dollars before the kit your gonna need a new engine within 10K miles of high rev. driving.
hmm i coulda sworn you needed high compression with F/Ibasically high compression means with aftermarket forced induction our engines will blow like a overfilled baloon poked with a needle. This is why successful FI requires a huge rebuild with low comp. pistons, stronger connecting rods, and stronger block sleeving. Kinda off topic but a bit of a warning to anyone thinking of the greddy or other turbo kits. Unless you prep your block for a FI set up for thousands of dollars before the kit your gonna need a new engine within 10K miles of high rev. driving.
Nope lower the compression is better for F/I, in fact if i recall the Evo is like 9.5:1 or something like that, this is also the reason why tC's with turbos do so well.hmm i coulda sworn you needed high compression with F/Iopcorn:
The reason lower compression is "better" with FI is because it leaves a larger margin for error. There really isn't a problem with boosting 10-11:1 compression engines, so long as they are tuned properly. If the tuning isn't "perfect" or if there is any unforseen situation that causes a lean condition, then the engine could grenade. The margin of error in tuning gets smaller and smaller as the compression of the engine goes up.Nope lower the compression is better for F/I, in fact if i recall the Evo is like 9.5:1 or something like that, this is also the reason why tC's with turbos do so well.
As for threads with such simple general questions please use wikipedia or google, theres tons of information there that can be tapped without having to make a thread and wait for responses.
they know what theyre doing as long as they dont alter the boost. But if you have a turbo set up maxing out your boost seems to be an obsession. Why pay $3400 on a set up thats only gonna add 40hp to the crank? Watch someone with the greddy kit on a track trying to dial up big boost on stock internals. Theyll be pissed when they hear a big boom and figure out they blew their block. Supercharging is a safer way to go on stock internals and adds pretty equal amount of hp for the same price. Also 10x easier to install. And the comptech CF cover looks pretty snazzy under the hood :thumb:wow really.. balloon popped huh.. i guess all those Greddy Turbo guys obviously dont know what their doing.![]()
boost levels being the same --a turbo will always make more hp...it doesn't have to drive the pulleySupercharging is a safer way to go on stock internals and adds pretty equal amount of hp for the same price. And the comptech CF cover looks pretty snazzy under the hood :thumb:
Amen! And completely agreed.they know what theyre doing as long as they dont alter the boost. But if you have a turbo set up maxing out your boost seems to be an obsession.
