1 - 4 of 4 Posts
Hey guys, I installed the Xtreme kit from XenonDepot a couple months ago, and everything has been working great until now. My driver side light flickers slightly when I turn it on for about 5 seconds, then turns off completely as if it quit trying.
I took out the fuse, and it seems to be fine. After putting the fuse back in, it did the same as mentioned above, flickered for 5 seconds and shut off. The only other detail I can think of is along with the flickering, there is a ticking noise that is associated with it.
The passenger side light works great though...
check the connections... check your harness from the hid bulb to the headlight plug unit.. it might be loose... that what happen to my hid kit
Checked all the connections, and everything seems to be tight. Still having the same issue... Can't figure out what it is.
Scrodums
1. Check your ground. Perhaps the flickering is due to a bad ground.
2. Switch the bulbs from left-to-right and right-to-left. This will let you know if potentially a ballasts (or bulb) is causing the issue.
My suspicion is a ballast though.
1 - 4 of 4 Posts
