1 - 14 of 14 Posts
... do you already have the fogs installed and wired?
It should be:
1. Unplug harness from halogen bulbs
2. Plug harness into HID ballast and connect ballast to HID bulb.
3. Put HID bulb in and enjoy
I don't see any part that isn't self explanatory.
probably too late now, but you will probably have to wire up the relay harness. I just did my HID fogs last night and they didn't want to start. Then I realized the ballasts are not getting enough current, as there is only a single 12V source from the fuse box. When the source splits in parallel, the voltage is still 12V to each plug but the current is half, which wasn't enough for my ballast. I then connected a relay harness that plugged right into my battery and it worked fine.
konradp: any pics of how you connected that relay harness?
OP: I am going through the same issue not knowing what to do with these 2 wires. Did you get your fogs to work?
everyone else: Any other input regarding the OP's question?
1 - 14 of 14 Posts
