i can get a bigger discount if i order them from myself, i work for Apple Honda in the parts department, lol, so i know the price i can get them for, just i have never seen what they actaully look like in person or in pics.Berlinas2k's has them.. You can get a big discount if you order from Collegehills.
so a 15% increase over stock just with the HFP parts isn't worth it, i beg to differ personally on that, sure i would also get SS line's aswell, brake fluid won't matter since it's not a track car, or won't ever see a track for that matter.
You need to flush the fluid every two years, no matter what and front wheel drive vehicles are typically hard on the brakes if you use them any at all. Your brake fluid is already getting warmed up by being near the exhaust manifold. pre-warmed fluid + some hard driving in the twisties = hot brake fluid, especially after a year or so when the boiling point drops 40 degrees from the absorbed water, which will corrode the caliper pistons and master cylinder if not changed regularly. Only a moron spends hundreds of dollars on brakes and doesn't do simple preventative maintenance.however again though, since it's not a track car, i'm not concerned about flushing out the current fluid,and replacing it with something i don't need since i won't see track time.
What warranty? Brakes are a normal wear item.id rather get them for the fact of the carry a warranty on them, and cause they are oem, i'd rather get it then some aftermarket hugely mass produced units where quality control is less a concern and more for quantity.
i have had the car for 2 weeks, why would i care to worry about a brake flush Yet?You need to flush the fluid every two years, no matter what and front wheel drive vehicles are typically hard on the brakes if you use them any at all. Your brake fluid is already getting warmed up by being near the exhaust manifold. pre-warmed fluid + some hard driving in the twisties = hot brake fluid, especially after a year or so when the boiling point drops 40 degrees from the absorbed water, which will corrode the caliper pistons and master cylinder if not changed regularly. Only a moron spends hundreds of dollars on brakes and doesn't do simple preventative maintenance.
under normal wear warranty can be thrown out, but for atleast 3/36 if something were to go wrong that wasn't normal wear, then hey i'm covered!What warranty? Brakes are a normal wear item.
Who the hell do you think makes your OEM brake rotors? It's not Honda, but some company working under contract to them. The difference between aftermarket and OEM is whose name gets slapped on the box. The metallurgy is what matters, not the already automated CNC machining process, since OEM and aftermarket are hugely mass-produced, else Honda, et al. couldn't make millions of vehicles per year; most rotors, OEM and aftermarket, are now made in China, Indonesia, Malaysia, etc.
In such case, Brembo is the cream of the crop, along with smaller specialty makers like Disc Brakes Australia. Many SCCA and NASA club racers use Auto Zone Duralast rotors with no issues beyond what they'd experience with more expensive rotors anyway, like cracking. Honda OEM rotors will heat check on the street because I've done it.
If I were to only stick with honda parts, 15% more for parts that perform a little better doesn't seem to be a bad idea at all. They are the same size as stock, they just have slots in them and have a little bit of red paint.so a 15% increase over stock just with the HFP parts isn't worth it, i beg to differ personally on that, sure i would also get SS line's aswell, brake fluid won't matter since it's not a track car, or won't ever see a track for that matter.
