1 - 20 of 35 Posts
· Registered
For those who care about such things. I weighed them 3 different places. When I weighed them at UPS I was surprised when it said 24.3 lbs since I got 20 lbs on my home scale. Then I took them to the Post Office and got the same thing. Hmm, that seems heavy so I took them out of the box and weighed the box. The box weighs 4.2 lbs, a lot more than I would expect. So 20 lbs it is. I do not know what the stock wheels on the EX coupe weigh but I am guessing a few lbs less, maybe 18-19.
The offset listed on the back is 45 ( I assume this is 45mm). I picked them up yesterday from the dealership. They won't go on though until Spring because I want to keep the stock 16's as winter wheels and use the 17's with a nice summer tire. I think they will look sharp on our Atomic Blue Coupe, like the College Hills pics with no underbody kits.
Edit: Should have stated that at home I weighed them out of the box. Stepped on the scale got my weight, then stepped back on holding the wheel (wifes idea).
· Registered
Discussion Starter · #7 ·
By the way the 17'' HFP wheels for the 2006 Civic are made by Enkei. Enkei is stamped on the back of the wheel. I would assume this is the case for 18's as well. 20 lbs is not the lightest 17'' wheel there is but it is also not the heaviest so not bad for a factory wheel.
· Acorns!
some scales are very inaccurate under say 50lbs. The best way to do it is to weigh yourself first. Then weight yourself holding the rim. Subtract the difference, and see what you come up with.
· Registered
re;17" HFP-R7 Factory Performance Alloy Wheel
Thanks for the weight info. Just wish I knew how much the stock 16's are. No one at Honda seems to know.
I went with the 17" HFP-R7 Factory Performance Alloy Wheel for my 2006 Civic EX because;
They match the Galaxy Gray on my car perfectly.
I didn't have to worry about wheel offset when ordering from a 3rd party.
Honda also provides the tire spec of P215/45R17.
Keeps my Honda Care warranty valid.
· Registered
Welcome to the site 1stcivic. Congrats on your new Civic!! Some good points you've listed. Post up some pics when you get the chance.
· Registered
17" HFP's
If your have a Galaxy Grey Metallic 2006 Civic these are a perfect match, exactly the same color.
You can tell from the picture that I’m new to posting pictures. I had to resize in paint and this is how it turned out with the bottom cut off a little.
Can’t wait for the good weather so I can put these on along with the 215/45YR-17 Goodyear Eagle’s F1 GS-D3 XL.
1 - 20 of 35 Posts
