1 - 10 of 10 Posts
Hello all :wavey: Name's Adam and I drive an 03 RSX. Figured I'd join the site to learn about the new Si to better help my decision between the choice of an 06 S or an 06 Si
Acorns!
welcome to the site. There is a lot of info around the site about the new civic/ civic SI. If you have a specific question - just ask! A lot of info is known about the car by quite a few members on here.
Discussion Starter · #4 ·
Basically is it a k18.. or is it a new series? and blueprints of the engine. I'd like to find out how nice of a n/a vehicle Honda has just made and most importantly the TBA price tag.
Thanks for the welcome!
Acorns!
The motor is the K20z3. The K20Z2 is for the current RSX-S engine. The K18 from what I understand is possibly the motor being built for the japan version of the 2006 civic.
K20Z3 compression - 11:1 197hp/139tq Civic Si (2006)
Basically follows the K series engine plans from the Current RSX-S
Prices - supposed to base under 20k. From some "unofficial reports"= $19,600 for base price.
You can get the car in 4 trim lines.
- without nav
- with nav
- without nav + high performance tires
- with nav + high performance tires
I haven't seen blueprints of the engine, but I'll look
Discussion Starter · #6 ·
I thought that the 2005-2006 RSX-S held a K20Z1, or at least for 05 it had. And I thought the 06 Si was to be a 1.8L which means if they are only manufacturing them for Japan, there will be no major difference between the 06 RSX and the 06 Si (USDM)?
Acorns!
the SI is fitted with a 2.0 liter K20Z3 engine - 8000rpm red line, I-vtec, drive by wire, 2 cam profiles, limited slip differential, and my bad- it's 11:1 compression ratio.
Acorns!
1.8L SOHC 140hp i-VTEC 4 (R18) is the base - DX, LX, EX line. Maybe you were thinking of this 1.8 liter engine?
Discussion Starter · #9 ·
No, I believe that I had just read a rumor a few months ago. I was lead to believe 200hp on a 1.8l but apparently not :) Thanks for the specs, LSD is a nice feature.
Acorns!
no problem shadowfly. It is definately a 2.0 liter motor in the SI, and the LSD is going to be great on this car! I can't wait to drive it myself.
1 - 10 of 10 Posts
