1 - 6 of 6 Posts
WORK IN PROGRESS, NOT YET COMPLETE. BARE HEAD AND BLOCK ARE STILL UNDER REPAIRS BY MACHINE SHOP SO I CAN FINISH WITH A FRESH ENGINE WITH NOT A SINGLE OIL STAIN AND SMOOTH MACHINED SURFACES
To start off, this swap will be completed in a shop, which means, everything is accessible and is easier with a hoist. This is just a general guide if you are trying to complete one your own.
I have purchased a full 2 door Si. This makes it cheaper to do a complete swap. This includes your electrical harnesses, brakes and suspension components.
I have a 4 door LX with rear drum brakes and no sunroof. This makes a good weekend track car as the LX weighs slightly less than the Si by approximately 300lbs.
Engine: stock aside from possible ITBs in the future, depending on my budget on this swap and Skunk2 exhaust
Transmission: Stock
Suspension: KW and camber correction. Fabricated frame braces/brackets.
Brakes: Acura TL Brembo brakes, and rear Si stock disc brakes.
So, here we go.
Parts list: (will be edited as I go with the build)
PROJECT SLEEPER
ENGINE:
*K20Z3 swap From 2door coupe Si
*Complete Engine assembly with accessories
*PCM
*Engine mounts
*Fuel low pressure flex hose
*AC lines
*(NEW) Starter cable
*(NEW) Ground cable
TRANSMISSION:
*Complete Transmission assembly
*Axles
Shifter bushings (Hybrid Racing)
Short shifter assembly (Hybrid Racing)
*Complete Transmission (Refresh)
- 2nd gear pops out, reverse gear grinds
*Transmission mount
Suspension and Tires:
KW V3 (Check budget on build - Currently on function and form type2)
Option 2: New F2 struts (RF has play, both rear struts squeaking)
Skunk 2 rear upper adjustable control arms
SPC Front eccentric bolts
Corsport rear frame brakes
Cusco Rear tower bar
Tanabe Front tower bar
Rays Gramlights 57V 41Offset 17x8
245/40zr17
*Front subframe (Refresh)
*Front knuckles (Refresh)
*Front lower control arms (Refresh)
*Rear subframe complete (Refresh)
*Rear trailing arms (Refresh)
*Rear spindle assemblies (Refresh)
BRAKES:
Brembo TL big brake kit
*Front brakes
*Rear brakes
*Front brake flex hoses
*Rear brake flex hoses
ELECTRICAL:
4 Door Si floor harness
4 Door Si Dash harness
Si PCM
Si Under dash fuse box
Si Under hood fuse box
Si Premium Audio unit (After market is optional)
Si Gauge
Engine and Transmission out of vehicle. Engine harness to be cleaned and inspected for corrosion
241535
Donor Car with Engine and transmission almost out
241536
The easiest part of this job is the subframe. Seriously.
241537
This parts car had been sitting for almost 2 years in our lot. So extra heat was needed to get the engine out.
241538
Here is the LX 4door.
241539
I will update this thread once I get the block and head back. While waiting, I will be removing the Dash harness and engine harness out of the 2 door SI. Will keep you guys posted!!
Block and head came back from machine shop. I guess my $80 for the block does not include washing and degreasing. Its just an inspection of the bores and ensures that there are no hair line cracks. Its okay, I'll do a final clean before it goes into the car.
Block assembly has begun. OEM head gasket is on back order until end of the month.
**New parts:
Piston rings
Connecting rod bearings
Crank shaft main bearings
Rear main seal
Oil pump o-ring
Intake valves
Exhaust valves
Valve guides
Valve springs
Keepers
Valve seals
1 - 6 of 6 Posts
