1 - 12 of 12 Posts
i had my sc for about a month, everything beeen dandy. till last week, when my exhaust gasket broke bc my exhaust is a lil too small. so tht was expected..
now today, im going home, boosted once or twice a day, nothing major. was in 6th gear doing 63.. when pressing the gas pedal, applying more throtle, i hear something beeen sucked , something from the intake i cant define whats wrong..
pulled over, poped the hood, checked for loose wire, the only wire i was able to find, was the 1 coming from under the blower and theres a hole which i think it goes it , that hole is located between the throttle body and the intake... if i dont give it enough throttle, everything works fine, but if i give it enough throttle, my intake does that weird sound... anyone got ideas?
im calling my installer tomorow, to get it checked out but i was wondering if someone had any issues..
no CEL.
what i suspect, its a line coming from under the blower and i think its supose to go in the hole that is located between the throttle body and the intake..
chris its more of a hose, i always read on here, the 1st thing that can go wrong was hoses or lines coming lloose, so that was my imediate reaction
Discussion Starter · #4 ·
i took a few pics, but they came out horrible..
if you apply more throttle, the car makes a weird sound , from the left side of the car..
Discussion Starter · #7 ·
my idle is goood.. idk bout the boost, since the weird sounds as i start to punch it. i didnt even attempt. tomorow il see and take more pics.. i hope its something simpleee and easy fix
Discussion Starter · #8 ·
update to whats going on? today weather is shitty, so i just wanted to see how the car ,, so i started up the car anddd dammmnn its looooudddddd asif i got an open header. then 20-30 secs later it started to quiet down. so some kind of leak?
maybe flex pipe broke?
or stock mounts seized??
il post pics later on today
By the way you discribe it bro, it seems like a broken flex pipe. But when you have a flex pipe broken the car sounds retarded and it looses hp/tq. What kind of headers do you have? You should get some skunk 2 rh. They are great and better then bcrh bc has no flex pipe neither.
1 - 12 of 12 Posts
