Ok guys I need your help I have searched and not found one thread with someone that has the same issue is me and its stressing me out!
Ok before I take my car to Honda I need a few opinions, The other day I was driving with my friend who also has an Si, mine is and 07 FA5 I started out from a light in 1st gear turned off the VSA and hammered it in 1st and went to power shift into second and It made a slight popping noise and started grinding but it was in the position as if it was in gear so I was like S**t.
I went into third and it went in fine tried going back into second same story. So I put it in 3rd went to forth which feels a lot further down than normal, weird so I went into 5th here is where the weird part comes in while in 5th which also feels a lot closer I push forward while in gear and the shifter moved further forward and buy doing that I can go into 2nd again but I cannot shift into it fast or the same thing happens again, so I’m like WTF seriously only parts I have are DCRH,TB spacer and Teins that’s it, any help would be extremely appreciated.
Thanks Skyler
Thanks Skyler
