So I swapped out a bunch of my factory speakers about two months back on my '09 FA5 for a set of Alpine SPS-600 (rear) and SPS-600c components (front). They worked fine minus a little bit of noise from the amp integration method. A few days ago I finally got my Alpine PDX-5 amp, hooked it up, and to my surprise everything worked perfectly the first time around...for about a day. I can now hear a cracking that sounds like it's coming from the front left tweeter, it's the kind of sound I would imagine you would hear if the speaker was blown.
What's weird is that I can only hear this sound when the car is moving (and even then sometime it won't kick in until a minute or two after I start driving or it will come and go while driving). The second I come to a complete stop, even if the car is running, it will go away completely. I swapped the outputs for the speakers on the amplifier and sure enough the sound traveled from the front left tweeter to the front right. So does that mean there's a bad channel on my amp?
Any help would be greatly appreciated, I'm thinking the amp is the problem but since this was my first amp install I thought it might be a good idea to get some 8th knowledge thrown on me first. If it makes any difference I don't listen to my music loud at all, I used the amp bypass harness rather than running new speaker wire, and as far as I can tell I have a good ground.
One last thing, when I received the amp it was missing it's "birth certificate" along with a few of the hex keys. I contacted the seller I bought it from (a very highly rated seller on Amazon) and he stated that either alpine left it out by mistake or I was accidentally shipped a returned amp from another customer. In either case he will exchange it without any problem if I so desire.
