Although I didnt but I watched and it was really easy.
After you get your lamps open you just need to drill two small holes in the high beam area to pass through wires so the angel eyes are anchored down. From the back side of the high beam reflector, you just use some epoxy so its permanent. Drill another hole up top to pass the wires through and the install is really clean. Done once the glue dries and back in the car within 2-3 hours max.
