1 - 20 of 31 Posts
Hey guys. I've been trying to install my Strup header for the past several hours. I have gotten the old header out, and the new header in, but when I try to bolt up the new header, I cannot get the header to line up with the bolts on the engine block. The reason for this (I believe) is that I can't get the correct angle on the bolts due to the bottom portion of the header hitting the frame of the car.
I think maybe that the mandrel bends on the header were slightly off, making it impossible to get the correct angle/position of the header to the engine block.
If anyone has any ideas or suggestions, please let me know, because I'm sure what to do as of now. Thanks.
Ok, so it wouldn't fit. I took it out and set it up against my old header, and the holes don't line up at all! So I'm going to be calling Strup and letting them know. I will keep you guys posted on what happens.
u have to keep playing with it to get the right angle.. its easier with a friend or someone to help hold the bottom end.. dont be afraid to use some force that is what the flex pipe is for.. pics would help also
lmao, no, the flex pipe is there for the sole purpose of allowing "flex" in your exhaust sytem when the motor moves.
wow:pat:, thats sucks, hope this gets resolved, ima check to make sure the holes line up during my install this saturday now.
Check as soon as you get the stock header out. Don't do what I did and waste 1-2 hours trying to fit it in before I took it out and compared the two.
I sent an email to Strup, and I will call them tomorrow if I haven't heard back from them yet. Like I said, I will let you guys know what happens!
Discussion Starter · #15 ·
That sucks. It should slide right on. All the Stroups should be the same
I'm not sure how they are made. If they are made in a die, then yes, they should all (theoetically) be exactly the same. Since the pipes are mendrel bent and welded, I would assume this means each piece and assembled/welded by hand, therefore opening the possiblity for slight variances. The problems isn't with the mandrel bent pipes or the welding though, it's where the holes were drilled to mount to the engine block.
There are 5 places you mount to the engine block, two of those are studs in the engine block that sldie the header on and put nuts over the studs, and three of them are holes to bolt into. The problem is with the studs. The holes on the Strup header where it slides onto the studs are drilled slightly too close together, meaning I can't fit the header on both studs at once. It will go onto one stud, and the other stud will be halfway lined up of the hole and halfway out. I'm not sure of the holes for the bolts are drilled correctly or not either, because I can't mount the header on the studs to begin with. From measuring with a tape measure though, the holes on the bottom seem fine.
I hope this explains the problem a little better.
where did you order it from?
WeSellCarParts.com - one of the site sponsers. This is not their fault in anyway though, so no blame goes to them, they did nothing wrong.
You must complete the right combination of jiggling, twisting and screaming at your bleeding knuckles and tired hands. Theres 1, just 1 angle that allows the headers to be correctly fitted to the block. Just take your time, have someone help you and remember which combinations of jigglets, twistings and screamings that you have previously completed (just because its frustrating to try something that you already know doesnt work.)
-FreuderLocks
Discussion Starter · #18 ·
I've tried for about 2 hours with someone else helping. It doesn't fit. We can get it lined up perfectly sraight and jiggle it and push on it all we want, but it doesn't fit on both studs. The holes on the header are just too close together. When I took the header out after trying for that period of time, you can see where the stud on the engine has been stratching the area right next to the hole.
I wouldn't make this up lol.
A similar thing happened to me, but I was able to get mine on somehow but the holes where off and when i was tighting the last bolt it wouldnt go on. found out it was the wrong header and that it striped the block.. :SHOCKED: so i had to have it helicoiled. it sucks theres a problem but be happy its not worse...
1 - 20 of 31 Posts
