MY 2008 2DR CIVIC IS THROWING CEL P0135 LOW VOLTAGE TO THE O2 HEATER CIRCUIT. I HAVE CHECKED POWER TO FUSE 11, POWER TO PGM FI SUBRELAY (BOTH SIDES ) ALL HAVE 12 VOLTS BUT STILL NO POWER TO THE BLK/WHT WIRE ON THE 02 SENSOR (A/F 1). I HAVE OHM CHECKED THE BLK/WHITE WIRE TO THE PURPLE WIRE AT THE FUSE BOX. IT CHECKS GOOD WITH .2 OHMS. I BELIEVE THE PROBLEM IS THE GROUND SIDE OF THE PGM FI SUB RELAY (RELAY SIDE) CAUSING THE RELAY NOT TO LATCH BUT I DONT KNOW WHERE THE GROUND FOR THIS RELAY IS.
IVE BEEN USING THE WIRE DIAGRAM AT THIS LINK.
Wiring Diagram
ALSO OUT OF COURIOUSITY WHAT OTHER CIRCUITS GO THROUGH THIS RELAY? ANY IDEAS?
Wiring Diagram
