You're getting a VSA? also, if your DashHawk can't read it then I have no idea
Followed the install guide carefully we're going to open it up and look for the problem tomorrow.I am guessing that he installed Toruku Street profile, which has more lift than the stock cams (approx. .010 more on the intake and about .050" more exhaust) and almost the same durations as stock, so the valvetrain upgrade is not that important with those.
My guess is that the install could be off.
It seemed to be running fine until i Vtec'ed onto the highway (which is when it died).
List of errors before it died:
VSA (both the letters AND the /!\ symbol) appeared on dash.
Cruise control would light up green like normal but wouldn't engage and show the second CC light.
Check engine light appeared on dash.
LMAO i wish i COULD Vtec the car won't start.. I have a couple friends coming over to help me turn the car around (It's in the garage at the moment too close to one side and facing the wrong way). Then I'll open it up and see if i can see anything wrong.timing is off, which guide did you use? i wouldn't vtec it anymore until the problem is resolve.
check the number of teeth between the markers on the int/exh cams.LMAO i wish i COULD Vtec the car won't start.. I have a couple friends coming over to help me turn the car around (It's in the garage at the moment too close to one side and facing the wrong way). Then I'll open it up and see if i can see anything wrong.
